Hitachi 53UDX10B 53" Rear Projection Television Logo
Posted on Nov 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Colors are out of alignment
Hitachi 53UDX10B 53. all three color guns go out of alignment. Blue is really out of alignment and picture shows double in blue.
Anonymous
Level 3:
  • Master 333 Answers
  • Posted on Nov 23, 2008
Anonymous
Master
Level 3:
Answers
333
Questions
Helped
200611
Points
1310
There is an alignment mode that you can get to. You must take off the back cover and look for the alignment switch I suggest that a tecnician do this because he has the propper tools and knowledge. If just an allignment is all it needs it should not cost that much. You have to try not to move this type of tv around because it is very sensitive and the slightest bumb can send it out of wach.
  • Anonymous Nov 23, 2008
    Do not take this unit apart unless it is unplugged electricity kills.
4helpful
Model# 53UDX10B bought in 2002. The green color has went off. Its a red tint picture now. Whats the repair and the approximate cost.
The tv have a problems known as a convergence problems,it dead.The tv have colors R,G,B lines mis alignment,have colors shadows or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Magic focus blue is fine, green and red are really blurry, tv picture is almost black and white. all bulbs are on.
Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the convergence board,to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
2helpful
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
How do I aling colors: the red and blue colors are not align making the tv look distorted.
On my Hitachi there's a convergence button on the front panel. Press that button which will give you red & blue lines. You have to use your remote to converge (align) those lines to correct the picture. If the lines won't converge I've been told it could be a bad convergence IC & tech is needed to fix...could be approx $300 to fix.
2answers
Double on picture
Ur Convergence is dead.U know how to solder?Buy the convergence kit use the parts and desolder and resoder repair.Tv Repair World.com to buy.
I HAVE DOUBLE COLORS ON SCREEN THE RED AND THE BLEU AT ONCE ON AND I DON'T KNOW HOW TO ADJUST .
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Hitachi Mo# 53uwx10ba double image
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Double images
You could have some type of convergance (three colors, three guns) problem. Also a misaligned horizontal or vertical oscillator.Ceck to see if any of tiny magnets around the bell of picture tube or next to coils in and around bell of pix tube are missing.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
