If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Drum will not start turning by itself.
Replace the starter capacitor. This is located usually at the bottom of the cabinet next to the motor. It has two wires attached.
SOURCE: dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
