Question about Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front load washer won't spin all the water out
Everything else seems to work ok, but the clothes are sopping wet at the end of the cycle.
  • ragnor2847 Nov 19, 2008
    The lock light still comes on.
  • Anonymous Feb 25, 2009
    I have a maytag neptune front load washer. The clothes were still wet after spinning so I selected just the spin cycle. The minute timer shows 9 minutes and then at the 7 minute mark the spin cycle stops.
    New Friend:
  • 3 Answers
My Maytag Neptune MAH5500B or MAH5500BWW wouldn't spin either. It would go all the way through the wash cycle, agitation and all, as mentioned before, the spin cycle would start at the 9 minute mark, and get down to the 7 minutes then drop directly to 0 with no spin at all.
After hours of investigation it turned out the balance load switch was corroded. This switch is accessible through the front panel of the washer. The door must be removed and the front panel comes off, this switch is directly under the wash drum where there is a little electrical plug and switch which rests on top of stabilizer styrofoam. The connection was being made but there was green corrosion, and evidently the switch box was corroded within. When bypassed, the washer spun perfectly.
Hope this helps someone else out there - I was horrified to think that this washer would end up more landfill as it wouldn't be worthwhile to pay hundreds for a new motor control board as had been suggested was the problem.
Posted on Jan 18, 2010
    Scholar:
  • 79 Answers
Or better yet... that board can be fixed for as low as $35.00... See www.neptunehelp.com for information on the Q6 R11 repair kit which includes a new 12002535 wax motor.
You have to replace the faulty wax motor or the control board will fail again.
There is a song and video that explains the faulty door latch wax motor on the MAH3000, MAH4000, MAh5500A and the 2000 stackers. That song is at www.neptunesong.com.
Also note: the earlier MAH3000's have (2) more of those darling wax motors in the soap dispenser that should be repalced as well. These control the bleach and softener flows...
Posted on Feb 25, 2009
    President:
  • Maytag Master
  • 2,651 Answers
Does the door lock light still come on, ???place in a spin cycle to check, if need be( it will take a min or so to light), if hte light never comes on i would remove three phillips screws from across teh top of machine console, there will be a circuit board mounted to the back wall, slightly left of center of the board youll find a light blue box,tiny maybe 1/2inch rectangle. interested in the resistor directly above that box, is theres abig burn mark around it??? if so there is your problem , youll need to replace the machine control board and also the wax motor in hte latch assembly( do not change one with out the other
Posted on Nov 18, 2008
  • Ron Coons
    Ron Coons Nov 20, 2008
    anotherissue maybe a motor control board, issue, not allowing unit to achieve a full speed spin, unfortunalty this is not such an easy diag, i would advise to call for service on this one, a nd a maytag authorized service as well, for the motor, depending on model and date of purchase may still be covered under some part warr( some where guarntted for 10 yrs)
    New Friend:
Have a neptune sometimes it washes and spins out or starts washing and stops and sometime starts to spin but not fast. sometimes does not want to drain but if put to spin cycle it will drain but not spin or spin slow and somtimes it will feel up and that all it will have to put it on spin to drain it .
Posted on May 13, 2013
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 20 Answers
SOURCE: Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Posted on Jan 19, 2009
Anonymous
SOURCE: maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Posted on Apr 18, 2010
Oloyede Monsuru
  • 1417 Answers
SOURCE: My Maytag Neptune model MAH3000AWW
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • Thanks you and thanks for using fixya.
    Posted on Oct 24, 2010
    I have a neptune top loading washer. Call PSEG service man out (had contract on washing machine). will not repair cost too much. Problem. end cycle spin -water will not come completly out of cloths....
    Yes Elizabeth if you don't DIY the fix it's no worth having a repair service touch the machine.
    I'm an knowledgeable owner and have helped many owners across 4 different forums save their $1K machine at reasonable cost. If you want to DIY I will help at this forum........ Google this ""FAV6800A/FAV9800A Outer Tub bearing replacement"" read thru the post and see if this is for you or someone that can help you DIY the work..............Good Luck dh1200s
    Aug 01, 2011 | Maytag Neptune FAV6800AW Top Load Washer
    Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
    if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
    Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
    My clothes are wet at end on my maytag neptune washer machine
    If you are spinning them on the highest setting try to put it on medium. Sometimes the highest setting is too fast and it will bang around and not spin properly. A lower setting will work better and the clothes will still come our dryer.
    Sep 14, 2009 | Maytag Neptune MAH6500A Front Load Washer
    Clothes wet
    If it is spinning okay and the clothes are still wet, then I would look at the water inlet valve. Check to make sure that the solenoids are good at the water inlet valve. They can be checked for continuity with a multimeter. If one of the solenoids is defective, it can let more water run into the machine because it is not closing completely. See the attached photo. Sure hope this helped and best wishes.
    Aug 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune frot load will not reach full spin speed.
    It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
    Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Washer Not Spinning All Of The Water Out
    It's not supposed to. They all keep water in the drum after wash is finished. Was told by Maytag its to keep the balance of the spin cycle, like balancing a tire with lead weights.
    Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
    How can i fix my washer myself?
    The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
    Maytag washer/front end loader
    HI...mine has just started dong the very same thing. I unplugged it to reset the computer and tried
    just the 'spin' setting....still...the water is still in the machine....not sure what to do. I thought a blockage too.
    abby
    Sep 08, 2008 | Maytag MAH6500 Neptune Front Loading...
    Maytag Neptune MAH5500B Front Load Washer Logo
    15,376 people viewed this question
    Top Maytag Washing Machines Experts
    jimorris77
    Sheldon Dedek
    Bill Long
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
