Model 110 20902 110 will not stop filling even when machine is turned off and unplugged.
You need to replace the water inlet valve on the unit. Here is a link to the part you need.
Washer will not wash
SOURCE: washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
SOURCE: Asko 620 washing machine keeps filling
Sounds like your fill solenoid has stuck in the open position. There are 3 #20 Torx fittings along the back and you can lift off the top panel. The solenoid will be in the back left side.
I would shut off your house water supply to the machine and then do a voltage check to see if the solenoid is remaining energized. Another more simple option is to give the device a few light taps as some debris may have become trapped inside and caused it to become stuck open.
SOURCE: Kenmore 70 series washer model 82870120 will not stop filling
you need to replace the water valve. This is a common problem and a very easy fix. You can order the part at sears.com via model number and also see a breakdown of the machine and how to put it in.
SOURCE: washer fills with water then stops, won't agitate or spin
There are two possible causes. The most likely cause is the lid switch, which is supposed to keep you from sticking your hand into the moving basket. On many washers this only keeps the machine from spinning, but on other models it prevents agitating as well. The other possibility is the water level switch, but that usually causes no filling or overfilling if it's bad.
Both parts are available from Sears (www.searspartsdirect.com) and many other online sources. (I normally use the Sears site to find a part number if I don't already know it, then search for that number on Google. It's a great way to find good prices on more costly parts.) There are also a number of sites with detailed information about how to remove the cabinet to get at the parts if you want to try doing it yourself. Replacing these parts is pretty simple if you're comfortable with a screwdriver and have some mechanical ability.
If you'd rather have someone else repair the machine, this would normally be about a 1 hour plus parts charge for an appliance technician. It isn't time for a new washer yet.
