Stihl 020av 020 Av Chainsaw Oil Pump Assembly Logo
simon causer Posted on Apr 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil pump on 020 stihl
How to disessamble spocket to get oil pump
Plink-plonk
Level 3:
  • Stihl Master 1,807 Answers
  • Posted on Jul 30, 2013
Plink-plonk
Stihl Master
Level 3:
Answers
1807
Questions
Helped
817772
Points
15648
Remove the side casing,then remove the spark plug and use a piston block to stop the piston rising while you remobe the clutch, once the clutch is off, the drum, bearing and oil work should be removable,along with the 2 plastic crank coveres. Once all this has been taken off you will have access to the oil pump.
2answers
Stihl ts410 won't start ?
check Stihl Decompression Valve - 4238 020 9400
https://www.diyspareparts.com/parts/stihl/decompression-valve-4238-020-9400/
1helpful
3answers
Oil is not getting to the chain with a stihl 012av chainsaw.
I'm almost sure you have to remove the oil tank and then the oiler
Can't get a spark on Stihl 020 chainsaw. Tried another coil and switch module but still no spark
It is possible your flywheel has lost it's magnet strength, if you noticed it turn a blue. Can take off flywheel and replace with a good one. Or you can play with the gap on the magneto/coil, and insert a piece of paper between the coil and the flywheel magnets, to set for air gap.
2helpful
Air gap and spark plug gap 025stihl chain saw
the air gap is about a business card thick and the plug gap is .020. Stihl has a special tool to measure exact air gaps so the business card is close
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
MS170 oil pump. I have investigated it. Worm gear was worn, repl'd it, pump is turning but no oil out port.
The filter in the oil tank may need to be cleaned.But you will most likely will have to replace the oil pump and it will have to be done at a stihl dealer. It requires special tools to remove and replace. George
To resent the timing on a 1997 3.0L Chysler engine, can you take the timimg belt off and turn the camshaft spockets to 12 degrees BTDC
ignition timing control by pcm.if you try adjusting timing by turning cam shaft you going to damage engine valves and pistons you are going to throw off valve timing when you turn camshaft.
I have a new ryobi ry09050 blower/vacuum and it is almost impossible to start. I Cranked for 30 minutes and no luck, not even a hint orf startion'g I would like a manual for this machine. It is either...
take the carby in for overhaul and new diaphragm kit fitted
the main diaphragm is hard and not sealing on the holes so it is not pumping fuel
40: 1 or 50: 1 is alright and the gap is .020-.025"
why I say that is that stihl use an oil that mixes as 50:1 but it is suitable for the full range of ratios in the stihl range of engines
makes no difference what brand of engine , the ratio is to ensure enough oil to lubricate the bearings and cylinders
1helpful
My Stihl 015AV leaks oil from the oil pump area. Any ideas? I've examined the pump, the gasket and the case and cannot determine the actual source of the leak.
This is an international collection of chainsaw enthusiasts with a few 2-cycle mechanics thrown in for good measure.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is discussing an oil leak on a Stihl 015; join in.
http://www.arboristsite.com/showthread.php?t=114962&highlight=stihl+015+oil
HTH
Lou
Jan 16, 2010 • Garden
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
