Need to know how to change the AC belt on a 2003 Chevy silverado 2500HD 2x4
You have to remove the main serpentine belt first. this is done with a 15mm wrench put on the tensioner. then from the bottom you can get to the a/c belt tensioner. install a 3/8 ratchet on it and remove tension from belt. I find the only way to get belt on and off is too slip it off the tensioner then off the backside of crank pulley then slide off of a/c compressor then install new belt onto the crank letting it fall off the backside run belt around compressor tensioner then work around crank pulley
change a fan belt with out ac
