Moved and when I plugged tv back in it keeps asking to run channel auto scan but won't pick up any channels.
SOURCE: AOC Plasma TV turns on by itself and changes channels non stop.
I have an AOC 32" LCD HDTV and it turns on by itself as well. Tuning is done via my cable box, so the tv is set on HDMI and I don't have the channel changing issue. I as well am trying to figure it out. The only thing I could suggest is perhaps the remote batteries are low and triggering on it's own. Try changing the batteries, or ensure that the remove it in a drawer or other room so that triggering the unit is impossible. Hope that helps.
SOURCE: I can't get any cable
Have you done an auto-channel search?There will likely be 4 different setups which it will look for channels.With regular basic cable,you definitely should get something.On mine,for the 4 different setups,it has DTV,TV,cable digital,and I believe digital HD.You need to open the channel menu and get to either the cable digital or HD to receive channels.Let me know if you have done an auto-channel scan first,then I can guide you better from there.Greg
SOURCE: envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
