Unable to program my philips television, i dont have the instructions
Setup codes to check with Philips TV are:
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Direct Code Entry
SOURCE: i need help programming my rcr3273 universal remote
Go to www.retrevo.com I found both the manual and the code booklet for my RCA rcr311w remote. you must register your email and it is in Adobe PDF form but its easy and free
SOURCE: RCA 430 universal remote
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcu430-manual.zip&area=other I had the same problem with my remote!! This helped me!!
SOURCE: instructions on how to program RCA universal remote control
This link is a .pdf of the manual with directions on how to program the remote as well as all of the codes for various electronic brands for all equipment (DVD, TV, VCR, etc.):
http://www.lexrixa.com/vcr%20codes.pdf
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red
indicator stays on and release button
3: press and quickly release what
you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly
untill your t.v changes channels(up to 300 times) if you over shoot the
channel change press down til it changes again.
5: press and release
MUTE to install the code.
SOURCE: philips universal remote #cl035a need rca tv, dir tv sat codes
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
I hope that this link helps you!!!.. Your Welcome.. I had the same issue.. tried this and hey! it worked.
