My power went out and when it came back on I received an invalid format error on my screen when it was plugged into HDMI. How do I correct this? I have and Olevia 232-T12
SOURCE: hd tv doesn't work at all says invalid format
is the tv 720 or 1080. it wont work if your inputing 1080p to 720p or 1080i
SOURCE: On my LG20LS7D using hdmi cable I get a blank
You get 'INVALID FORMAT' because the video signal source resolution is too high for the TV to display, you need to lower your video source resolution.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
SOURCE: Olevia 232 T12 when you go from standby to on, blank screen
Sounds like power board or main board. check with olevia support and give them your model number and explain your problem. a lot of these parts have lifetime warranties and the service call is free. hope this helps.
SOURCE: Invalid format
Try rechecking all wire connections for proper placement and fit too and from the tv.
Try adjusting the video format on the DVD, flip through 480p and 1080i. See which format works best with your tv. Do the same with Wii.
See if this helps.
SOURCE: I plugged my ps3 in my olevia tv and it comes up
Nothing is wrong with it. It's only compatible with 24 Hz, 25Hz interlaced, 30Hz interlaced, and 50Hz.
I was trying my ps3 on the OLEVIA and said invalid format
