When I turn my camera on it the lens comes out and it makes it's normal "on" chime, then the lens goes right back into the camera and it shuts off. I have tried taking the battery out and putting it back in, charging it, taking the sd card out and putting it back in. If I turnthe knob on the top to my favorites, it allows me to view my pictures on the sd card but as soon as I turn the knob to take a picture it turns off. Please help. I leave for vacation soon and I don't want to have to purchase a new camera.
SOURCE: the lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
SOURCE: My camera turns on and turns off right away.
charge it ,but if you got charger from box switch it so you got one that fits into bottom of the camera
SOURCE: THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
SOURCE: Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
SOURCE: I turn the camera on to take a picture and it
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can
prevent the full power of the batteries from
flowing into the camera.
Try this free fix before you do anything else: remove the batteries and
wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera and give them a full
charge (assuming that you're using rechargeable batteries). This
cleaning clears
the problem about 90% of the time. If it doesn't work for you, it may be time to replace your batteries, or the
camera may have
a problem that requires professional repair.
If this response helps, please take a moment to post a rating. "Very Helpful" would be appreciated . .
