Remote control key
SOURCE: Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
SOURCE: No sound from our Sony Wireless Home Cinema System
Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
SOURCE: Sony BDV 370 home cinema system and Sony 40hx703
You need to use a HDMI 1.4 Cable and it needs to be connected to to an HDMI socket with an ARC (audio return channel). Alternatively you can connect using an optical cable (TOSLINK).
SOURCE: My Sony DVD Home Theater
Specs and manual:
No.
http://www.retrevo.com/support/Sony-DAV-DX255-Home-Theater-Systems-manual/id/750dj490/t/2/
Remote available here:
About $51 delivered
http://cgi.ebay.com/Sony-parts-147964111-RM-ADU003-REMOTE-CONTROL-/360325260367?pt=LH_DefaultDomain_0&hash=item53e50f244f
about $58 base price
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=RM-ADU003&uuid=A12956152737951
