First thing check the connections. check and test the continuity on the power or the main board.
and there a possibility that you have a damaged screen.
the loud pop sounds occur usually due to blown capacitor. Make sure none of the capacitor are burnt. Please look carefully since sometimes you dont notice a small crack in it which causes the pop.
If not, no video sounds like video unit is faulty.
Again have a look on the circuit board if any component has burnt.
Replace the tv lamp. Click this http://www.alltvlamps.com/product_p/ts-cl110uaa.htm for inquires. Please dont rate me if not satisfied with my suggestion. Thank you for using fixya...
HELLO
you have a tube problem
last time in my computer
this type of problem happened.. then i called a repairmen
he told me in this their are vertical IC and horizontal IC
so in my case my both the ic are damaged
that fellow reapired it by fitting new tubes
same in your case ........ just repaired it
ok
he charges 3$+3$ for this
now every thng allright
thanks for using fixya
golu_fixya
Loud pop sounds like blown capacitor.
Are you sure none of the capacitor are burnt? Please look carefully since sometimes you dont notice a small crack in it which causes the pop.
Again have a look on the circuit board if something (component) has burnt.
Do you remember how this happened ? or did it happen all of a sudden?
First thing check the connections you do. chect and test the continuity on the power / main board.
Please check any cold solder near the lamp. Check any blown/bulge capacitor and any other nearby components. If you found one, replacing it will fix the problem
The bulb is working fine it is lit up bright.
I am not getting graphic video or input video. On the screen.
I replaced the power board with a new revised version. Double checked all connections several times
This is my daughters TV. She told me that for a few days the tv would come on ok but would shut off after an hour or so time. It would not restart till it cooled. Finally one day it popped and no sound no video no light no led lights nor light from projector lamp. I called a service rep he said it could have been a bad power board. I took off the back cover and found dust blocking most of the fan duct screens and a blown lamp.
As a safety factor I replaced the power board
and replaced lamp cleaned ducts. Verified all fans are working. TV powers up with all normal led indications. Projector lamp is on bright.
Audio works from all inputs. However I cannot get the menu to come up nor any video input.
I called JVC rep he talked me through a reset using the side panel Menu buttons and power switch. No change. I dont no weather Ive got a digital card problem or is it the $1600 optical engine to replace?
I dont need basic guesswork here I need some one who has actually seviced this tv
I called JVC rep he talked me through a reset using the side panel Menu buttons and power switch. No change. I dont no whether Ive got a digital card problem or is it the $1600 optical engine to replace?
I dont need basic guesswork here I need some one who has actually seviced this tv model
The bulb I removed was pretty much shattered internally
