Fridge was working fine a couple of days ago. I noticed that the ice maker was not making ice and then this morning I went to get an ice pace and it was not frozen. The fridge seems warm too.
When the refrigerator turns on, do you hear anything in the refrigerant lines? Does the compressor turn on? or does it just hum?
If the compressor is running, it lost refrigerant charge. They were not made to be serviced and lack service valves.
If there is just a loud hum, the compressor may be siezed, the start/run capacitor may have failed. or the magnetic starter failed.
A service call is a fair portion of a replacement not counting the parts.
SOURCE: fridge is not cold and freezer is not cold
the vents might have glogged by some thing or maybe there is some airleaking from the doors and preventing the freezer to reach the necessary freezing temprature.check out.
SOURCE: Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
SOURCE: fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
SOURCE: fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Testimonial: "It sounds like you might have the right answer. Have to wait till we can check it out. Thanks for the suggestion. TL"
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
The compressor seems to be working . I tried turning the temperature all the way down to see if that helped and it didn't either. Hoping to not have to get a new one.
