Toshiba Satellite M45-S165 Notebook Logo
mel rod Posted on Apr 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dark spot on lcd due to improper cleaning
I tried to clean the lcd using a damped cotton and i think its the reason why my laptop screen got damaged.
David Towner
Level 2:
New Friend:
  • Expert 53 Answers
  • Posted on Apr 30, 2012
David Towner
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
23979
Points
169
What liquid did you use to clean it? Only mild soapy water is suggested, other cleaners can damage screen. If you press to firmly on an LCD Screen, you can cause this also.
1helpful
2answers
Is there a process known to man that cleans windex streaks off an lcd screen?
How to Clean an LCD Screen
So, first of all, let's decide what we don't use to clean it:
Anything containing bleach or ammonia, such as Windex. That will react with the plastic and make the plastic screen become cloudy and discolored.
Anything sharp, pointy or abrasive.
Your easiest choice is one of those LCD cleaning solutions they sell in places where they sell computers. But they're expensive, and why bother when you can make your own solution for next to nothing?
What you'll need:
Distilled water (available at your supermarket; tap water leaves streaks and minerals).
White vinegar (you may substitute isopropyl alcohol; either way, make sure these substances are diluted before they come near your screen).
A clean, soft cloth (never use any kind of paper product).
A spray bottle.
Directions:
In the spray bottle, mix the distilled water and alcohol/vinegar, in a 1:1 ratio.
Turn off the LCD display.
Spray the mixture onto the cloth, never directly onto the screen.
Wipe gently - oh, so gently - from top to bottom. Do it horizontally, too, if you think that leaves a cleaner result.
Let the screen dry before turning it back on.
Hands Off!
Fingers leave dirt and oil smudges that must be cleaned off. Also, every time you touch the screen you risk doing damage to those tiny creatures inside that hold the colored flashlights. Keep your fingers to yourself.
tip
PC Tools- How to clean your computer
  • Cleaning the Computer
If you've noticed that your computer's keyboard feels sticky or the monitor screen appears spotted under the light, it's time to clean these pieces before internal damage occurs. Cleaning your computer's keyboard does not require special knowledge or skill. But you should take precautions to avoid damaging the internal parts when caring for the external hardware.mike_alozie_0.gif
1. Unplug the computer and all accessories before getting started. Anytime you attempt to clean an electric appliance it is important to disconnect the power source to reduce the risk of electrocution or shock. After unplugging the keyboard and monitor, along with any accessories that may be plugged in, use a damp clean cloth to wipe all the cords that are connected to the monitor and keyboard and remove dust balls or hair, along with anything else that might cling to them.
2. Move the computer monitor and keypad to one side of the desk and wipe the area clean where the equipment usually sits. Be sure to wipe a large parameter around the monitor area and let it air dry completely before returning the keypad to that area. You might want to use a clean towel or dry cloth to rub over the desk to be certain it is dry, as dampness can damage the machinery or cause it to stick to the table's surface.
3. Rinse the damp cloth in clear hot water and wring it nearly dry. Gently wipe the monitor screen, including all the corners, to remove dust and spots. Then wipe the surrounding areas and framework of the monitor, including the indicator lights that show when the system is operating. Don't forget the back of the monitor as well. If you have a laptop computer with a top that folds down and closes, wipe the hinges carefully, using a cotton swab for grooves and the latch. Check the latch to see if it is sticky or closes readily.
4. Next, go over the keyboard with the cloth, lightly rubbing around each key and button. Wipe around the sides of the keyboard, catching the off and on switch and CD player. Then use a cotton swab to ease around the edges of each key and row to retrieve minute amounts of dust and crumbs. Carefully clean around the lights, plug openings, and speakers, as well as other areas of your computer. Check to be sure you are not leaving wet traces on the equipment, as this means your cloth is too damp and should be wrung out more.
5. Allow the machinery to air dry, or use a soft cloth to pat the keyboard and monitor dry. Don't use fabric with lint or that is tough enough to scratch the screen. Reassemble all the cords and parts when you are sure the entire unit is clean and dry.
Plan to clean the keyboard and monitor every month or two. You may want to schedule maintenance for an interior cleaning once or twice a year. A clean computer is more likely to work well and last longer.
on Apr 25, 2011 • Computers & Internet
tip
How to clean an LCD TV
<span>An LCD screens must be cleaned as it attracts dust like a magnet. Cleaning is risky as the screens are very sensitive and there are chances of you damaging the screen if you don't know the proper method to clean it. To help you in this read the article below to the various tips on cleaning the LCD TV.</span> <b>Tips On Cleaning LCD TV</b> <b>Basic Facts About LCDs</b> <ul> <li>LCD screens or displays should not be cleaned through normal methods, as they are not glass. LCD or liquid crystal display is a soft film and it can be damaged through improper cleaning agents.</li> <li>The popularity of LCD TV's is on a rise as they can be can be run on low battery power and also have<a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>sharp</span></a> picture clarity.</li></ul> <b>LCD Screens Problems</b> <ul> <li>LCD screens regularly gather dust and smudges and sometimes fingerprints and ink markings.</li> <li>Cleaning the screens with a <a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>paper</span></a> towel, dishcloth or tap water can do considerable damage, as the screens are very sensitive. It can cause clouding and can cause damage to the pixels.</li> <li>Tap water contains chemicals like chloride and wiping the screens with it can leave a residue on the screen.</li></ul> <b>Cleaning Tips And Guidelines</b> <ul> <li>The LCD TV must be cleaned regularly for you to enjoy the proper clarity of the display.</li> <li>First of all, turn off the LCD TV and examine the condition of the screen.</li> <li>Note the smudges and the areas to be cleaned.</li> <li>To remove dusts use a microfiber cloth and brush off the dust particles.</li> <li>It is best to use proper cleaning solutions that come with LCD cleaning kits. However, you can mix one part of isopropyl alcohol with one part of distilled water and using cotton or microfiber cloth, clean the screen. Another cleaning solution that can be made at home to clean LCD TV's is to mix one part of vinegar in one part of water. Pour this solution on a soft cloth and then wipe the screen.</li> <li>Take care not to spray any sort of cleaning solutions directly onto the screen. Instead take it on a piece of cloth and then wipe.</li> <li>Wipe the screen in a circular motion and be very gentle. Don't press hard.</li> <li>Also do not touch the screen with your fingers or there are chances of leaving oily prints.</li> <li>Rub a soft cotton dry cloth to completely remove excess liquid from the screen as the moisture may damage it.</li> <li>Before switching back the TV on, let the screen dry completely.</li> <li>If some stains or marks are hard to remove, don't apply pressure to remove it. Instead, repeat the cleaning procedure several times to get rid of it. For ink marks and other hard stains, you have to invest in special cleaners.</li> <li>To clean the dirt from the edges or corners use a Q-tip. Dip one end of the Q-tip in the cleaning solution and squeeze out the excess moisture from the cotton tip. Now gently drag this tip along the edges.</li> <li>Do not use cleaning solutions that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the LCD screen materials and damage it.</li></ul>
on Jan 18, 2011 • Televison & Video
1helpful
What is the best way to clean a 46" LCD Toshiba TV
You do not want to use any harsh chemical or anything in excess. What I use and recommend is simply water and dish soap such as ivory. Use clean lint free paper towels or cotton or soft fabrics. You put a drop or two of detergent on a damp towel.You gently wash the screen then wipe it dry. The towel needs to be damp but not enough so that you get any running water.You may need to do it in small sections. If you use too much soap you get streaks. If that happens just get another damp piece without soap and go over and then use the dry to wipe the screen dry. The soap takes off anything without harming the anti-glare coatings on the screens. The wrong type of alcohol or a harsh cleaner can strip these coatings off or damage the plastics. Dish soap and water is very safe dirt cheap and found in the kitchen usually. ;-]
2answers
How to clean LCD monitor?
Monitor wiping cloths. You can get then at any Wal-Mart, Staples, Frye's, etc.
5helpful
3answers
Samsung LCD screen cleaning technique
Hard crusties? what do you do to have this type of matter on the screen?
Be carful with what you use on the screen, a damp cloth is permissable. This does not mean spraying liquid directly on the screen and wiping it
Spray into the cloth or dampen cloth and wring out well. Do not let any excess water drip down the screen especially if it gets into the TV via the outer frame around the screen.otherwise poof it will never work again
please rate our help to keep the service online
1helpful
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Faint white spots on macbook pro lcd screen
If the spots remain in the same place I'm sorry to say no. Be careful what you clean the screen with. I'm a fan of a warm wet damp only rag. Using alcohol or other cleaners may damage the surface. There are also cleaners available at local stores. You don't need anti-static on an LCD display. The spots can be from pressure on the display applied at some point even if that pressure happens when closing or transpoting your laptop.There is no way to fix it.
Screen
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
