My washing machine keeps tripping my main fuse box. I've changed the fuse in the plug but the problem still occur's. Does anybody have any idea's on how i can fix this?
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
SOURCE: Hi,Ihave a hoover hnf 7167
hi
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
Hi
The washing machine is obviously
drawing too much current for the breaker to handle. This could be due to the
washing machine drawing more that it should or because the breaker cannot
handle the current the machine needs, coupled with the other machines on the
ring main. If the fuse on the plug of the washing machine does not blow, then it
could be that there are too many appliances on the ring main. The fuse on the
machine may not blow however, if the breaker has a faster blow time than the
fuse in the plug. Try plugging the washing machine into another ring main. Or
try plugging out all the other appliances on the same ring main and test it
out.
If the ELCB (Earth Leakage Circuit
Breaker) is tripping only when the washing machine is running then something in
the machine is faulty.
One common problem is the heating element. Over time they tend to crack and
when the water gets in, the ELCB will trip out. This can be problematic to
diagnose as offten the element will only trip after a period of heating. Bottom
line, if it is tripping the ELCB then it is dangerous and should be fixed
before any further use.
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
