Question about Vision Fitness T9250 Deluxe Folding Treadmill
I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Visualization is the path that can helps you to work accordingly. https://www.amazer.me
Posted on Mar 29, 2019
    Top Expert:
  • Vision Fitness Master
  • 12,223 Answers
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
I have a vision fitness treadmill T9250 and now th - 5_3_2012_12_57_12_am.gif
Posted on May 03, 2012
2 Suggested Answers
6ya staff
SOURCE:
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: How to fold Vision Fitness treadmill T9000
Sorry this model Treadmill does not fold up. You can get the manuals on the link below.
http://dl.owneriq.net/2/2f5f5d37-f094-4074-8b96-d6fe3bb59d27.pdf
http://dl.owneriq.net/a/af4a953c-36cd-490d-8215-4014994b6830.pdf
Good Luck
Posted on Jan 05, 2011
The belt catches when running. it is fine when walking. Vision Fitness T9250
There is a special lubricant spray for treadmills that you spray. injection pump. The air injection pump is designed with a check valve inside which only allows air to flow in one direction, preventing exhaust gases from escaping through the air pump and only allowing air to enter. When this check valve fails, moisture is able to get inside the air pump. Make sure you don't have dirt and dust build-up before spraying.
Sep 11, 2017 | Vision Fitness Exercise & Fitness
My belt has stopped working, but all other functions are fine. I've removed the motor cover, but now what should I look for?
Try to check the carbon brush of the motor. If it's OK then the motor control board would be faculty
If you wish to get some more details about treadmill repair then check the following link
http://electro-medical.blogspot.com/
Aug 20, 2016 | Vision Fitness T9250 Treadmill
My Vision Fitness T9250 treadmill. Can hear a low noise when no one is on it but gets much louder when anyone is on it and operating...any ideas where to start looking for repairs?
Try to open and separate the motor carefully from treadmill chasis, turn the motor shaft with hand if it not easily turn or you hear a unsual sound try to open the motor and add a lubricant to motor bearing, and turn the motor on if its still noise replace all the bearings with new one
Dec 14, 2014 | Vision Fitness T9250 Simple Folding...
E4 coming up on my screen display , what is this and how do I fix it so it will work again ....
What device are you talking about your stereo ATV a computer or a cell phone?
Most manufacturers have a support site on the Internet and given the error code and the model number they'll give you a solution
Nov 25, 2014 | Vision Fitness T9250 Deluxe Folding...
Vision fitness premier T9550
please see the chart attached. However Tight the upper and lower connector +ribbon cable inside, and clean it. Adjust the REED swtich attached diagram, clean it, and tight very well the connector.
Merry Christmas
Dec 18, 2013 | Vision Fitness - T9550 Folding Treadmill...
Getting E2 error on my vision fitness t9250 treadmill
68a1477a-4453-48c8-9f94-cd15c6c6fea7.giffollow this steps and fix it. God bless you
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
See the diagram attached.
Oct 13, 2013 | Exercise & Fitness
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
I have a Vision Fitness T9600 and when I start it, it doesn't go any faster than .5 mph. When I push down on the arrow keys, nothing happens. The elevation doesn't repond to the pushing of t
You must measure the 8' 12 vDC Voltage to display from the terminal from Controller board motor.
If there are the Console Board is faulty. However tight very well and cleaned it with electronic spray cleaner.
If there are NOT, the controller board motor is faulty, some IGTBs are faulty. REPLACE
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How to Determine If Treadmill Console Is Broken
Nov 26, 2017 | Exercise & Fitness
Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
STEP 1 ENTER ENGINEERING MODE
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
Life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Feb 28, 2009 | Life Fitness Remanufactured Next...
Vision Fitness T9250 Deluxe Folding Treadmill Logo
989 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
ray gallant
Don Eagan
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
