Kenmore dryer won't start. when press start button and hold, hear the click and nothing move. All the selected buttons and all lights in the controll panel are working normally. after press the start button, the time on the display start to count down as it operates normally. I check the door connector is good. Your help will be appreciate.
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer. You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
SOURCE: Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Your motor has fried. It isn't in the Control Panel, the SENSES light wouldn't turn on if it were the CP. If you go to your closest Home Depot, ask the front desk for assistance with Dryer Motors. They will guide you through to get you the right one. They will even tell you how to install it. When you replace it with the new motor, the Dryer will work fine.
If this helps at all, please rate this a FixYa. - Evolution
SOURCE: Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
