There is no other way.The only thing you can recover the certificate is to flash the phone.So, Click here2 for instruction if you want to do it by yourself.And from this link you can download the rm495 flash file.Good luck
SOURCE: while downloading any application i
JUST FLASH YOUR PHONE AND EVERYTHING WILL BE FINE. I RECENTLY GOT THE SAME ERROR AND I DO FLASH. IF YOU DONT KNOW FLASHING THEN VISIT TO YOUR NEAREST MOBILE SHOP AND TELL THEM TO FLASH IT.
SOURCE: My nokia 5130 xpress music
Hi
Not aware of the 100% solution and never faced such problem too.. but try updating / re-installing the firmware.
SOURCE: msg comes "no certificate on
just Click here1 or contact mobile tech.Here is your 5130 flash file.This is the best way.Good luck
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
