I have a new Maytag MGC7430 gas cooktop. At first it was fine, but after a few weeks when I was cooking I could smell gas above the burners. There is no smell of gas anywhere else, at any time -- just when the burner is actually lit. I thought I was imagining it but the problem is worsening and yesterday while boiling potatoes the smell filled the kitchen. Obviously we turned it off, disconnected, etc. but nobody can figure out what's happening. Any ideas?
SOURCE: Can't boil water on new Maytag Gas Cooktop
No adjustments. You will need the correct orifices. Contact maytag to get the correct ones. They should send them to you for free.
SOURCE: GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
SOURCE: Thermador gas cooktop explosion
I would say that pop was one of you igniters. either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop. I would say that I would use caution and discontinue its use. Most problems with these need to fixed professionally.
SOURCE: all cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
SOURCE: gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
