Have you checked to see that the waste is not blocked? THis is very
common on these machines and causes the pressure switch not to operate,
making the machine fail to spin or spin with water in the drum,
causing unbalance symptoms.
This is extremely common on Hotpoint machines without a accessible
filter. The filter is in the rubber waste pipe under the drum and needs
to be removed to be cleaned out. When iti s blocked it also blocks the
chamber that operates the pressure switch.
We have an ultima wma66 and it has developed the same problem does quik spins at start of wash etc. Have just checked the filter taken a few items from it, but it is still happening.
