Question about Canon MP280 All-In-One InkJet Printer
Canon mp280 error 5100
Alarm light is flashing and the printer won't take command to print. screen says error 5100. restarting printer does not fix the problem
  • amit
    amit Dec 07, 2013
    earro 51 printing stop
    New Friend:
Clean the encoder tape
Posted on Sep 12, 2012
  • lucena98
    lucena98 Sep 12, 2012
    clean the encoder tape
5 Suggested Answers
Anonymous
  • 120 Answers
SOURCE: Error 22
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Jan 28, 2009
Rob Gutierrez Rios
  • 118 Answers
SOURCE: I have a Canon PIXMA MP530 printer and showing an
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
Posted on Mar 02, 2011
Anonymous
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
Anonymous
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: error code 5100 on canon pixma mx700
5100 says the carriage is not moving all the way across the paper path. There could be grease or ink on the encoder strip, the clear strip behind the carriage. Or a small paper scrap inside stopping the carriage.
Posted on Aug 10, 2009
How can I remove rear panel to clean out paper drive?
PDF]Canon MP280 series On-screen Manual
content.etilize.com/User-Manual/1017865665.pdf
See Operation Panel. .... Lights or flashes orange when an error occurs, such as paper-out or ink-out. .... You can switch the size of paper loaded in the Rear Tray between A4 and 8.5" .... Remove the original on the Platen Glass after scanning is completed...... For details on the printer driver settings, see Printing Documents.
Jan 07, 2016 | Canon PIXMA MP280 Multifunction Printer -...
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
Canon printer: PIXMA MX700 I removed the paper from the paper tray when the printer was about to start printing. Then I received error, 1500, on the printer's screen. I have put the paper back to the...
This is a strange one. There is no error 1500. I suspect you meant error 5100. This can happen when you have a paper jam.
1st When you pulled the tray out was the paper still left in the machine.
2nd If it was then did the whole sheet of paper come out when you pulled it out?
3rd If no then some paper is still in there and u need to find it and carefully remove it.
4th If yes then you may have done something to the carriage as that is was error 5100 refers to.
Take a look inside and you should see a thin plastic strip running from left to right the full width of the machine. It is called the encoder strip and it may have flipped onto it's side. All the cases need to come off and the strip needs unclipping and refeeding through the carriage.
Look at the flashing lights (thats the alarm and power lights) they will be flashing. They will flash twice the wait a second then flash twice again and so on. That will confirm the carriage is the problem. If you dont feel up to it then take it to a canon repairer and not joe bloggs as getting the covers off without breaking them is quite a job.
good luck
Apr 23, 2011 | Canon Office Equipment & Supplies
When I try to print in my Canon Ip6210D, the alarm indicator flashes and the message of error 5100 appears in the screen. Could someone help me please?
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Jun 11, 2009 | Canon Pixma iP6210D InkJet Photo Printer
Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
May 30, 2009 | Office Equipment & Supplies
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Canon printer pixma ip6220D is showing error code 9000 alarm light flashing. What to do please?
Canon printer pixma ip6220D is showing error code 5100 and alarm light flashing. Help me how to repair it?
Dec 21, 2007 | Canon PIXMA iP6220D InkJet Photo Printer
Canon MP280 All-In-One InkJet Printer Logo
7,674 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
