SOURCE: oven will not lite
Replace the oven ignitor. IT probably still gets red but it has to draw enough current to open the gas valve and yours isnt. Replace the ignitor and it should fix you up.
SOURCE: igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
SOURCE: GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
SOURCE: Our glow bar lights up when gas oven is turned on,
Typically the issue here is a weak glow bar (hot surface ignitor). When they weaken they open the gas valve slowly and it takes a bit for the ignitor to light up the oven burner.
It is a safe bet that you need to replace it.
