SOURCE: amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
SOURCE: Kenmore Upright 13 cu.ft freezer- uneven freezing
no it sound like there is a problem with the seal system where the freon is kept this model does not have a fan because is the shelves get frosted so there is a leak or restriction so try calling a tech but i would just buy a new if i was you since to fix will cost about the same
