Question about Sharp AR-5316 Advanced Digital Imager Copier
How to chande the developer
I've read that you chenged the developer on your Sharp AR-5316.
How did you do that?
I've no idea on how to start...., can you give me some hint?
Thanks,
Andrea
  • 1 more comment
  • andre964 Nov 22, 2008
    Dear,
    thanks for the your reply.
    While waiting for an answer I was looking around for the answer and I found 3 post where people say that in this printer I don't need to change the developer since it is included in the drum (someone says in the toner) unit and so when I change the drum I change the developer too...
    http://www.fixya.com/support/t337439-sha...
    http://www.fixya.com/support/t345862-sha...
    http://www.fixya.com/support/t325327-add...
    ...I'm confused!
    I changed the drum a month ago and I didn't reset any counter.
    Should I just reset the counter? (Which? How???)
    Thanks,
    Andrea
    Thanks a lot!!!!
  • reddah ilyes
    reddah ilyes Nov 30, 2013
    get into SIM mode by pressing "#" key then "interrupt" key then "C" key then "interrupt" key again. enter 42 then press start - enter 01 then press start.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
You take the drum out, then unscrew the developer (it should be a greenish screw), it should slide out, empty the developer out, take bag of new developer shake it up real good... then pour evenly into developer unit, while turning the mag roller... reinstall..
Posted on Nov 22, 2008
  • Anonymous Nov 22, 2008
    This machine, the Developer is apart of the Toner Cartridge... (I apologize; I didn’t realize this model toner came with the developer attached)
    This is a link to the Operator manual, look at the Maintenance section. It gives instructions how to change and reset the maintenance counters..
    http://www.sharpusa.com/files/cop_man_AR...
    ( If this link doesn’t work, go to http://www.sharpusa.com and search in the Business copiers section)
6ya staff
SOURCE:
How to remove code f2 from a Sharp AR-5316
What is the next after f2- or if f2-64 check development un or connect the connector chip.Replace development unit.
Jun 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Installer of sharp AR-5316
Remove the screws marked and all tapes around the copier, open the tray and remove the screw supporting it. Open the front cover and unscrew the green screw holding developer unit and pullout the unit. Open the 3 screws and pour the developer evenly and return it back. Remove the seals on the toner cartridge and insert it. Power on the copier and make a copy.
Nov 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Cheng treey sharp 5316
hold the key with the L alphabet pointing left for 3 sec and use the enter key to select your paper size and when finished press the START key.Do not for get to adjust your paper tray accodingly.
Jan 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
263 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
