How do i download the manuel for panasonic camcorder model SDR S45
SOURCE: Uploading video to Mac
You can't transfer videos through USB. You will need a Firewire 6-pin cord and use it to connect from your MAC to the Camcorder. Only then you can transfer videos.
SOURCE: Panasonic SDR-H40P/PC
This camera will only work with the latest version(s) of iMovie (08 and 09). I'm not sure, but you may need an Intel-based Mac also/too. Any previous version (for example, iMovie HD, aka version 6) will NOT work with this camera out of the box.
There is a workaround. You will need the MPEG2 Playback Component for Quicktime from Apple ($20) and a free program called MPEG Streamclip. I also use OS 10.5 (Leopard), and this has worked for me. Once the component is installed, drag the .MOD files from the camera (it will appear as a disk on the desktop when you plug it in and turn it to "PC Connect" mode) one at a time into MPEG Streamclip. Then export them to the DV file format, which is what iMovie uses. Depending on the length of the clips, this can take a fairly long time. Good luck.
SOURCE: Need Panasonic SDR-H40 software download
You can connect to any computer with a USB port. It appears as a hard drive after you tell the camera to connect (in the menu). Then just copy the .mod files to a spot on yor computer; there will be one for each movie clip.
Your next chore is changing them into MPEG files at the correct aspect ratio. If you shot in 16:9 they will be squished together unless you use the SDCopy freeware utility to set the widescreen flag. It also renames and downloads files for you, and it's small. There's a link from this tutorial page, which also explains a lot about aspect ratios and such:
http://www.elurauser.com/articles/JVC_Everio_mod_files.jsp
SOURCE: Panasonic SDR H40 and Video Cam Suite 1
I have the same problem. What I will do is download the camera to a DVD recorder using the A/V cord which came from the camers. I purchased AVS4U program for $59 lifetime option with free frequent updates. I can down load the DVD to the computer and I can format them in about all possible formats eg WAV, MPEG 2 etc. I can edit the songs, etc to how I want them. I do this with live performances of our band "Charlie Horse Band" and I can record the whole set (up to an hour) and I can manipulate the final product with the editing functions of the many AVS4U products that come at the one price.
Hope this helps!
SOURCE: Need software to download Panasonic SDR-H18 palmcorder.
forget Nero - terrible software that costs and arm and a leg - waste of time - thanks for nothing, fparton
