How do you remove the front panel and remove mesh screen on an ACER Aspire AM3470 desktop computer to add an additional DVD drive?
I also have an Acer Aspire AM-3470G & just swapped DVD drives trying to troubleshoot a problem. Remove the one side panel with the finger tab that gives you access to the system board/HD's, etc. No need to remove the opposite side panel. With the panel off, there are 3 black plastic tabs holding the front cover on. Release them so that the front panel pivots to the opposite side which also has 3 black tabs. Those tabs will release themselves as you pivot the front cover. You may need a bit of force to pivot the cover so be careful not damage the plastic tabs. You'll now have complete access to the DVD tray area. The DVD is held in by 2 exposed screws, there are none on the opposite side of the drive. Unscrew them, disconnect the power & SATA connectors & slide out the drive. If you replace the DVD drive, test the new one before you reassemble all the covers to verify everything works.
SOURCE: My acer aspire 5630 notebook Has a messed up cd/Dvd Drive
You might look into an external cd/dvd unit.....they connect via usb.
SOURCE: acer aspire 5102 with philips sdvd8821 dvdram drive
alright. bubul78, your post is in no way shape or form a solution for the problems given by other users. I too have a acer laptop with the philips dvd drive in it, device manager detects the dvd reader and says it is running with no problems. i can hear the drive read the cd when inserted, tho when trying to access the drive through my computer the window hangs at the hourglass for a min or so, then says please insert a cd. only solution is that something is physically wrong with the drive. ok so solution found, replace the cd drive. but where is acers sight to order replacement parts? poor site navigation in my opinion.
SOURCE: I have an Acer Aspire 5738z and my dvd drive
http://www.sevenforums.com/hardware-devices/38426-dvd-drive-not-working.html
SOURCE: I need a replacement internal dvd drive for an
you can try ebay, here is a link to one of them
http://cgi.ebay.com/Acer-Aspire-5738G-DVD-RW-ROM-RAM-Drive-Burner-/150521815727?pt=PCC_Drives_Storage_Internal&hash=item230bcca2af
Also, you can try your local computer shop, sometimes they have used laptop dvd drives
I have to get the cover off both sides of my ACER Aspire to add or remove a dvd drive. The one side slips out but the other side cover includes the top also. Any ideas to get the side/top cover off?
This chassis also has two buttons on the side to pop the drive I have and the one I want to install. What do these buttons tie to.
