You may download a copy of the manual here.
SOURCE: Panasonic Palmcorder Camcorder sdr-h40p/pc Software
For the VideoCam Suite 1.0 (software) that comes with the camcorder requires Microsoft Windows xp professional service pack 2 but I have service pack 3. How do I transfer from the videocam to my PC?
SOURCE: Panasonic SDR-H40P/PC
This camera will only work with the latest version(s) of iMovie (08 and 09). I'm not sure, but you may need an Intel-based Mac also/too. Any previous version (for example, iMovie HD, aka version 6) will NOT work with this camera out of the box.
There is a workaround. You will need the MPEG2 Playback Component for Quicktime from Apple ($20) and a free program called MPEG Streamclip. I also use OS 10.5 (Leopard), and this has worked for me. Once the component is installed, drag the .MOD files from the camera (it will appear as a disk on the desktop when you plug it in and turn it to "PC Connect" mode) one at a time into MPEG Streamclip. Then export them to the DV file format, which is what iMovie uses. Depending on the length of the clips, this can take a fairly long time. Good luck.
SOURCE: Need Panasonic SDR-H40 software download
You can connect to any computer with a USB port. It appears as a hard drive after you tell the camera to connect (in the menu). Then just copy the .mod files to a spot on yor computer; there will be one for each movie clip.
Your next chore is changing them into MPEG files at the correct aspect ratio. If you shot in 16:9 they will be squished together unless you use the SDCopy freeware utility to set the widescreen flag. It also renames and downloads files for you, and it's small. There's a link from this tutorial page, which also explains a lot about aspect ratios and such:
http://www.elurauser.com/articles/JVC_Everio_mod_files.jsp
SOURCE: lost ac power adapter ac cord panasonic sdr-s7 camcorder
Go to Radio Shack, bring your camera, and they will sell you an AC adapter part number: 273-1696 for $30.
SOURCE: Panasonic SDR-H18 connected wrong AC adapter
I accidentally connected wrong ac adapter and to Panasonic dvd camcorder and it will not turn on.....Hopefully this can be corrected??
