Watches Logo
A
Anonymous Posted on May 04, 2012
Timex expedition wr100m alarm
How do turn off alarms
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 02, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4985
Points
0
TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
5 Related Answers
Anonymous
  • Posted on Sep 30, 2009
SOURCE: Alarm
On this 1440 watch to cancel the alarm first push the adjust button (bottom right on this watch) this will bring up the alarm time previously set and while still holding the adjust button tap the stop/start button (top right on mine) this should deactivate the alarm
Anonymous
  • 3 Answers
  • Posted on Aug 18, 2008
SOURCE: setting tha alarm
Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
Anonymous
  • Posted on Oct 24, 2009
SOURCE: New Battery but Alarm sound doesn't work
You will find an arrow head on the outside back of your watch where all the printing is. When you put this lid back on, this arrow needs to be aligned with a notch on the inside edge where the cover goes on. As you are looking at the watch from the back with the cover off this notch is in a northwesterly direction. If you doubt it then just hold the back on without popping it in all the way and hit your mode button to make sure that you hear the beeps again. If you do, then you've found the right spot.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 26, 2010
SOURCE: How to set the alarm for the Timex Expedition
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, plz.
Anonymous
  • 111 Answers
  • Posted on Aug 29, 2008
SOURCE: Timex Expedition alarm beep
good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
I have a timex expedition. Eventhough the battery is new, the alarm and the beep function does not work properly. I have to shake the watch to make it work
If your Timex Expedition watch alarm and beep function are not working properly, even with a new battery, it could be caused by a few different things. Here are some steps you can try to troubleshoot the issue:
  1. Check the alarm settings: Make sure the alarm is turned on and set to the correct time. Also, check that the alarm is set to the correct mode, such as daily or weekly.
  2. Check the watch's manual: Refer to the instruction manual that came with your watch to see if there are any specific instructions for setting the alarm or beep function.
  3. Check the vibration function: If the vibration function of the watch is not working, it could cause the alarm and beep to not function properly. Try resetting the watch or contacting Timex for assistance.
  4. Check for physical damage: Inspect the watch for any physical damage such as a cracked or broken case, or a damaged alarm switch.
  5. Check for water damage: If the watch has been exposed to water, it could cause damage to the electronic components. If water has entered the watch, it is best to take it to a professional watch repair center for service.
  6. Check if the watch have a warranty: If the watch is still under warranty, you should contact the manufacturer for service or repair.
How do i set vibration on alarm on expediton watch
Janice, set vibration alarm to on expedition watch. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Enable Vibration Mode for Alarms on Timex Expedition W214 Wristwatch
https://answers.yahoo.com/question/index?qid=20111002092048AADRLYs
http://www.timex.com/info/watch-manuals
Can't turn off the alarm on a timex Expedition Watch
buy a Casio wrist watch at KMart for around $17.00. They last five years, then the
band breaks and you buy a new watch. I timed the traffic signal system of our city for 20 years from a Casio wrist watch. Now in retirement, I have a Time Expedition which has several alarms which I do not need, and can't turn off. We change the time twice annually, so having alarms and chimes go off without warning ca bve a nuisance.I found some instructions on a website which shows how to turn the alarms off.
3helpful
2answers
Alarm on timex indiglo won't turn off
It's just a cheap watch, one hit with a hammer and the alarm stopped.
3helpful
Manual needed for Timex Expedition MF13 as I cannot change the digital time and to know other functions
Hold your "SET" key for few seconds,and then "ALARM" to increase the count.
Use "MODE" key for switching a digit place again use "ALARM" key for increase a count and at the end press "SET" key.
13helpful
3answers
3helpful
Setting alarm on watch
You should be able to download the manual for your watch at the site below. If you cannot, contact Timex for support.
http://assets.timex.com/manuals/index.html
Jerry G.
1helpful
Setting tha alarm
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
