Rockstar Games Grand Theft Auto: San Andreas for Windows Logo
Posted on May 05, 2012
When i click the icon it shows 1065 error
My computer os is xp when i click icon it show error 1065 please contact support@longtion com .for help .
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
655
Points
Install onto windows vista
Your having problem with Silent Hunter 3 on you windows Vista, It is because Silent Hunter 3 is not compatible with windows Vista. Maybe the game may work if you play it with XP compatibility. Heres how to do that.
  1. Locate the shortcut icon of Silent Hunter in your Desktop.
  2. Once you locate the icon, right click on it and click on Customize to show the Customize Menu.
  3. On the Customize Menu, Select Play and then click on Edit. ( This process will show you the Properties Screen)
  4. On the Properties Screen, you will find the Compatibility Tab, Click on it.
  5. find the sentence that says " run in compatibility mode for: ", you will see a drop-down list underneath it. It contains all the OS that can be compatible with your game.
  6. Browse the drop-down and select Windows XP.
  7. Click Apply and OK then close the Customize Menu.
  8. Now your game will try to run in XP compatiblity mode.
  9. Your done. Run the game now.
If the solution above doesn't work and you really want to play the game. I suggest you change your operating system in which the game is supported.
Goodluck , Hope that this solution will help. Please give some feedback regarding my solution thanks.
Thank you for using Fixya!Have a great day!
HOW CAN I LOAD WINDOWS XP IN WINDOWS 7? I MUST USE BOTH BUT AT DIFFERENT TIMES SINCE SOME PROGRAMS WHICH I HAVE ONLY COMPATIBLE WITH XP....
follow the link below.it will show you how to install dual OS.
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html
Say "Thanks" by clicking the thumb icon in the post that helped you.Please click "YES" in solution that solves your problem as "was this helpful?"
The icons on my desktop are not showing up. Also
What is ur OS? Icons can be restored by right clicking on the desktop and selecting the option "show desktop Icons" in windows 7. In windows xp also there is function like that. So check it out.
Hot to retrieve my desk top icons
OK what OS are you using..I am assuming Xp or Vista...I am assuming XP
These are desktop icons not system tray icons right...
This is for XP only if they are desktop icons...
To resolve this behavior, turn on the Show Desktop Icons feature:
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
  4. If that didn't work go here:
http://support.microsoft.com/kb/330170
2answers
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
1helpful
Not showing up in my computer
Error code 19 implies that Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device.
Restart your computer, when is booting up select THE LASK KNOW GOOD CONFIGURATION that might help to fix the damaged registry
To correct this error, Use the link below and follow and click on the Fix it button to automatically correct this error or you can scroll down to the steps corresponding to OS you are running on your PC to perform these steps manually
http://support.microsoft.com/kb/314060
1helpful
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
H D Audio Driver fails to install
Have you checked to see if the driver is already installed, and the volume is just turned down? (Start> programs > accessories > entertainment > volume control) If so, try going into Device Manager (right click My Computer > properties > hardware > device manager) See if the sound card is showing up there as a yellow question mark or other error icon, it will stand right out. If it's there, right click, and uninstall it. Now (still in device manager) press the button that looks like a computer screen with a magnifying glass on it, that will scan for hardware changes and pick up the sound card, which windows includes the driver for automatically. If this still doesn't work, try downloading from realtek here, and installing that. Hope this helps.
2answers
My dvd drive is not being seen, computer states software problem code 19. HELP
Hi Samholden,
If I understand correctly you are not able to find your DVD/CD drive listed under the "My computer"(computer in Vista)
When You try to use the Disc on the Drive,the Error"code 19" Pop's up.
Is the Light indicatng the Power to the Drive showing On.
If Yes Please Follow this solution For XP (operating system)
Click Start,
Right Click My Computer.
Click Properties.
(you should have got the system properties window Open)
Click Hardware TAB
Click Device manager Button
Look through the list to find the DVD drive (icon)
if you Find it and see a "+" sign Click it to make it "-"
then Observe the sub menu that appearce, (Reply to us if there were any of the alert Icons along with the ICON)
Right Click the sub-menu and Click uninstall.
then Restart the computer again.
please ask if you find ay Difficulties.
Thank you
XP Bootup on Compaq
if in the starting it is showing two operating system then make sure that which one is working and which one you want to remove
then boot your system with xp and right click on the my computer icon> go to properties >click on the advanced tab > then choose startup and recovery setting > there you will see defaukt operating system if it is showing two operating system then remove the OS which you dont want. Be careful to use this option.you can reduse the time limit also.
Top Rockstar Games Video Game Consoles & Games Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
MegaByteMe
MegaByteMe
ADMIN Andrew
ADMIN Andrew
Are you a Rockstar Games Video Game Console and Game Expert? Answer questions, earn points and help others
