When i turn on the machine the message code appears SC829 0301 0xA4000004. There are anything i can do?
SOURCE: I have a ricoh 2051
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
SOURCE: hi sir i have problem in ricoh 1035 machine
2nd laser synchronization error
The 2nd laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
Clean to the crystals
and mirrors inside the laser
Poor connection between the laser
synchronization detector board and
the LD unit.
Laser synchronization detector board
out of position
defective
LD unit defective
if you is not technician you need call one to make this work.
SOURCE: sc:829 code:301 detail:A4000001
there is something wrong in that machine this making it display this error code. The error code has a meaning and this meaning needs to be interpreted first, before the problem can be identified.
The error code means; charge Corona problem. The charge Corona of your machine is defective and that's what causing the problem. The charge corona is a power pack and it is located inside the drum of the machine.
To be frank, you will need a technician to help you service the machine in other to get it fixed.
Good luck.
