I have almost the same problem with a DX 6620. the drawer won't open, if opened manually it closes automatically but then opens again without playing the CD. I would like to keep this CD player, it cost me about $ 300,- in 1990 and it is part of my Onkyo system.I have almost the same problem with a DX 6620. the drawer won't open, if opened manually it closes automatically but then opens again without playing the CD. I would like to keep this CD player, it cost me about $ 300,- in 1990 and it is part of my Onkyo system.
You can't post conmments that contain an email address.
Being that it is an old unit, even though it worked just fine except I had to open and close the drawer by hand. I sent it to the trash bend, It was an Onkyo C110. Thanks anyway!....Bob
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
I also have a problem with the drawer. It opens when I switch the unit on and when I close it - it opens again!
If I switch off at the mains the drawer remains open - to prevent dust ingress I have resolved to holding the drawer in whilst shutting down the power until I get a solution.
Try slowly opening it with a flathead screwdriver. Get the tray open enough to put ur pinky in and try to remove any disk(s) that are in there. Plug it in and turn it on. If the tray closes ur system should be ok and try to open it with the button. If no good. Then try agian, but this time slowly open it all or most the way, then plug it in and let the drawer close and see if the button works to open and close it.
This is ussaly caused by a jam from either a incorrectly inserted disk and it jammed the tray. Or the gearing that is connected to the motors jamed up and the tray needed to be moved out to unlock the jam.
Closing the tray with ur hand and not pressing the button to close it also could of caused this problem
That happens when you close the drawer instead of pressing the close button you can skip gears and it would have to be taken apart and re-calibrated. Sometimes it is just a glitch that you can over-ride using a straight pin into a small hole on the front (assuming this uses a drawer).
When idsk is not recognized it is because the laser mechanism can no longer focus on the disk. If this happens with all disks then the unit is fubar and it is time to go shopping since repair is not cost effective.
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
