LG Flatron Ez T710BH 17" CRT Monitor TILT/SWIVEL & BACK COVER REMOVAL 1) Set the monitor face downward.2) Carefully remove the Tilt/Swivel by pulling it upward.3) Pressing the latch (b), Back cover by pushing it upward.4) Release the latch (c). (See Tip Spec.)5) Slide the Back Cover away from the Front Cabinet of the monitor.
This is more likely an issue with you video card than your monitor, do all the monitors you have tested operate at the same resolution and refresh rate? It sounds like the LG monitor is running at a higher resolution and refresh rate which is causing addition load to be placed on your video card causing it to crash
Your resolution or screen refresh rate sounds like it is too high.
Try dropping your resolution to 1024 x 768 and see if the issue persists.
If it does then perhaps your game is trying to force you into a higher resolution output and faster screen refresh rate than your graphics card or your screen can handle.
Assuming that the graphic output is fine when your not playing this game and just using windows?
there is a lock system to this monitor put crt front portion on table take a smallest screwdriver insert it into the narrow gap and pull the cover upperside it will open there are two gaps anyone you can try
