have you had the battery checked for holding charge ? has alternator had charge rate checked ? 13-14 volts is recommended,if these ok and still have all these symptoms get the ECU checked,hope this helps
you will have to disconnect 1 circuit at a time and find the problem, have many ideas at once, like 5 things changed at once, problem solved? 4 items were OK but you still don't know what the problem was. just 1 at a time
Have you taken the battery to autozone or someplace and had the battery tested? I would find if you know the alternator is good it must be the battery itself. Might want to try that if you havent already. Good Luck Bro~
sure!can you charge battery? if won't start charge the battery and take it to nearest autozone or advance auto parts and as long as your check engine light is on,,, they will code read for free, then they will tell you what or where problem is.if not then try this,,,put in fully charged battery,start it,,disconnect the positive cable from battery while engines running,careful not to let the positive cable come in contact with any metal of car, if engine dies,,altenator not charging,may be bad diode in back of the altenator or blown fuseable link inbetween starter and altenator.hope this helps and if so please note so in response. thank you for choosing fixya.com
I have a 2000 grand vitara. The check engine light has been off and on for years. It stays on for months at a time then goes off. Doesnt seem to be any engine problems. Must be a problem with the light.
escudo 2.0 V6, the idle is ok and the rpm quite ok, but smoke is so heavy when start in the morning, it dosent run smooth. can you help me to, i already change the spark plug but same stoyr, any solution?
