I have systemlink 3 rca remote contol. what is the code # for rca tv?
If your remote control has a search button, this is how you do it--------
User submitted information for the SystemLink 3:
To clear things up and make it simple, here is how to
program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
Test remote on device, if ALL functions do not work,
repeat above procedure.
***IMPORTANT NOTE***
Count how many times you press the On/Off button. If ALL
funtions do not work and you need to repeat, you don't
want to stop at the same non-working code. For instance,
if it takes 23 times to turn your device off and after
testing, the remote does not control all functions, repeat
steps 1-3 BUT when the device turns off at the
23rd time, turn it back on using the power button ON THE
ACTUAL DEVICE then continue with step 3 and 4 from above.
