Question about Brother PC-420
Stitch doesn't catch
Was working fine, but now it doesn't catch the stitch
  • gracet
    gracet Sep 09, 2012
    Thank you. I think it needed a cleaning, especially under the plate. I used my vacuum cleaner, as well as my air cleaner for my laptop, then changed the needle and it worked. So simple, thank you again.
  • Brother Master
  • 7,365 Answers
Have you tried changing the needle?
clean under the needle plate for lint or thread
Posted on May 08, 2012
    Champion:
  • Brother Expert
  • 300 Answers
The only thing YOU can do is to put in a brand new needle, a bent needle will cause that problem. If that doesn't work, you need to bring it in to a Brother shop for adjustments.
Posted on Sep 07, 2012
  • gracet
    gracet Sep 09, 2012
    Thank you.
  • jessica silver Oct 01, 2012
    any chance you can tell me if the adjustments can be done ourselves without voiding the warranty? I live in Canada and have to cross the border for any physical help from brother... gets expensive quickly as you can imagine!
6ya staff
SOURCE:
I have a Necchi 535FA sewing machine that will not catch either the thread, just leaves a stright line of thread not catched
try changing the needle
also try rethreading the machine top and bobbin
make sure the bobbin is turned the correct way in the bobbin case
if the suggestions don't help then it's possible that the machine
needs to be checked for a timing problem
Jan 15, 2013 | Sewing Machines
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
The pattern (stitch) selector doesn't work when I turn it
it sounds like you need a new pattern selector dial & it wouldn't
hurt to have the machine checked to see if the internel part of the
dial is ok inside
Oct 11, 2012 | Singer Featherweight II 117
Thread wont loop, it doesn't sew?
It loops, it's just that your shuttle isn't catching the loop. The loop is formed on the upstroke of the needle on the back or "scarfed" side of the needle. If the shuttle point doesn't catch that loop, no stitch.
First make sure you have a fresh needle. If still no stitch... take it in for service. (clean, lube and time)
Oct 03, 2012 | Brother SE-270D Computerized Sewing...
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Second Needle thread isn't stitching
change the second needle
rethread the second needle & every thread guide
see if that helps & if it doesn't then the machine needs to be checked
Aug 13, 2012 | PfaFF Sewing Machines
Tension too tight/ bunching up/ a mess
rethread the machine top & bobbin
change needle
back off the tension until the stitch doesn't look so tight
May 17, 2012 | Barbie 11301 Mechanical Sewing Machine
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Hello. I am working with a Singer 6083C. When I turn the wheel, the thing in the bobbin goes around but the thread doesn't catch. I'm wondering if this is because I've put the bobbin in...
Have you recently changed the needle? If so, please check if it is in the right way, flat shank to the back. This is easy to get wrong and will prevent stitch formation as the scarf at the back of the needle (scooped out area) is where the rotary hook goes to catch the thread during stitching.
Jul 13, 2011 | Singer 6038 Mechanical Sewing Machine
I had my machine in the closet for 5 years and now need to sew a hem on my cotton pants. What should the settings be set at? Right now it is at a 4 and the stitch length is a 2 1/2. The thread is too...
If your machine has been stored for 5 years, you should give it a good clean and oil according to the manual before you do anything else. Then put in a new needle and wind a fresh bobbin, checking that the bobbin has been wound smoothly as a badly wound bobbin can cause poor tension and stitching from the bottom thread.
You want the thread to go from the spool through a tension disc or eyelet to the bobbin and keep some gentle tension onto the thread spool using your scissors handle or similar so that the thread winds off it smoothly and the spool doesn't bounce around. Also give the thread a nudge with your finger tip as it winds onto the bobbin so it fills evenly, top, middle and bottom, not all in the middle.
Are you wanting a straight stitch to sew around the hemline? If so, your stitch length is right, but stitch width should be zero. You don't say what knob is set to 4, if its your top tension then that should be close, usually between 4 and 6 if dial goes from zero to 10.
Which thread is too tight? top or bottom. Firstly check the threading path to ensure that the top thread isn't catching on anything, is through the take up lever properly and coming from the thread spool without catching there. Some thread spools have a little knick in the top where you can catch the thread to store it, but you dont' want the thread to catch here when seaming, so turn it around the other way on the spool so it can't.
Try test stitching a medium zig zag stitch on scrap fabric, and you'll be able to see if the bottom thread is pulling in or the top one, then adjust the tension dial a little to lessen this.
Hope these pointers help, if you can't get a good neat stitch after trying these things, then consider taking it for a clean and service, the technician can get inside and clean the machine thoroughly and also check for any other issues that might be there.
Apr 30, 2011 | Singer 57815 Mechanical Sewing Machine
Brother PC-420 Logo
162 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
