Hi,ref hitachi 42"pd660,im connected to sky,xbox,dvd,only on tv,sky channels especially sports the pictures terrible, fuzzy with white vertical lines down screen 1-1 half inch apart,tried all ,sky signal good satelite dish ok,cant retune tv?really frustrating me can anyone give advice on re tune or new set up config,oh ive also bought new scart from sky to plasma no joy
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
SOURCE: my tv is hitachi 55pd plasma
snoopmikeym - Have you found anything out on what is causing the line?? I am completely frustrated with Hitachi no tech help what so ever. The nearest service place is in a town of about 500 people and 30 miles away... I doubt they've worked on a 55" plasma before....
SOURCE: ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
SOURCE: 42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
SOURCE: Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
SOURCE: vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ??
3. If yes ..?
4. Then change the LOGIC BOARD or PDP
