Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator Logo
Doug Smith Posted on Dec 17, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridge problems - frigidaire
I purchased a frigidaire side by side a month ago and have noticed even though I keep the freezer at (-3 F) the items in the freezer are soft to the touch. Now everything is thawing. The freezer is at 36F and the fridge is at 48F. I try to change the temp to a lower temp but it will not cool. The unit is only a month old... any tips? Thanks
  • 1 more comment
  • skyizik Jun 12, 2008
    My amana br18 is doing the same thing. I have removed panel in back of freezer & defrosted it. this lasted for about one and a half weeks, is building up with frost again. what should i do?
  • momo266 Feb 04, 2009
    I have a Frigidaire fridge freezer model FRE-196AS which I purchased 15 months ago and has run out of warranty.The freezer compartment is alright but in the fridge compartment ice builds up around the drainage filter which is located at the back of the fridge compartment and above the salad tray. I have even tried leaving the fridge below the recomennded fridge temperature but it dose not seem to be working.
  • Anonymous Mar 29, 2014
    My Frigidaire refrigerator does not cool. The items in the freezer thawed out and the refrigerator side does not cool. The fan inside works, but I have shut the controls to zero. It is located in my garage so it may just be dirty coils, but thought I would ask. Thank you.
Anonymous
Level 2:
  • Expert 237 Answers
  • Posted on Dec 20, 2006
Anonymous
Expert
Level 2:
Answers
237
Questions
Helped
455436
Points
660
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 04, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
896
Points
I have the same defrost problem and detrermined the control board to be bad. After installing the new board, the display keeps flashing zeros and won't allow a setpoint change. Is there a special procedure for installing this board? My unit is an Amana afd2535deq.
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
2helpful
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Fridge on the Fritz
sounds as if perhaps theres a fan in the freezer, copartment that is not spinning, circulating the cold air around, or if that fan is spinning you have adefost issue,not "self defrosting so the ice is building up preventing proper circulation
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Blinking temperature control
You need to check the limit thermostat for the defrost in the back of the refrig section. I replace it with a standard bi-metal type from a Frigidaire to keep the problem from reoccuring.
2answers
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
