Question about Whirlpool WTW6500W Washer
Whirlpool Cabrio Wtw6500 won't spin
TUB DOES NOT SPIN
6ya staff
SOURCE:
Anonymous
SOURCE: Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Posted on Sep 30, 2008
Michael Childers
  • 240 Answers
SOURCE: F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Posted on Mar 14, 2009
Anonymous
  • 175 Answers
SOURCE: Whirlpool Cabrio has started displaying error F50
hi..the reason to this problem is the RPS(Rotory positon
sensor).
check it out..
thank u..
kindly rate my response..
Posted on Jun 29, 2009
Anonymous
  • 12 Answers
SOURCE: My Whirlpool Cabrio sounds like a jet engine while
believe the bearings can be bought locally,but water seal has a Whirlpool number on it that will not come up on pricelist on my Whirlpool program.I am looking for a way to cross ref. this seal and repair the tub.The last tub was over 197.00 cost for new tub and drive shaft ,bearings and seal.The bearings are Korean made and can be bought locally for alot less than a whole new tub.This is an ongoing problem with the Cabrios and Maytag Bravos that I have seen lately.Also a few of the Sears Kemores out there.There has to be an easier and cheaper repair for these thousand dollar machines.I dont like telling the customer its going to cost them 400.00 to repair their washer when it is not even a year out of warrentee.If anyone has the seal number or a cross number please post
Posted on Mar 04, 2010
Anonymous
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
Posted on Mar 29, 2010
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio model wtw5500xw0 spins loud
The cabrio has a shaft that runs between the wash plate and the rotor located under the washer. The usual cause for noise during spin is something that has made it's way between the spin basket and tub. But it's best to try and determine if the noise is from under the washer or inside the washer, that way you aren't randomly taking things apart. See if you can pin point the location of the noise.
Oct 18, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw5600xw0 will not spin
There is a spin sensor that is part of the shifter if this is wet it wont sense the spinning, hence wont spin, and if it is wet you mat need to replace the tub seal http://www.appliancepartspros.com/gearcase-motor-pump-parts-for-whirlpool-wtw5600xw0.html
May 29, 2012 | Whirlpool Cabrio Washing Machines
What can I do to get my WP Cabrio washer to drain & spin?
Your drain hose has to be higher than the water level in the tub, almost up to the top of the tub
Dec 30, 2011 | Whirlpool Cabrio WTW6600SBK
I have the Cabrio WTW6600SB, when I'm washing, I'll get to the rinse/spin cycle. the Tub starts to woble all over and bang sides of machine, then I'll get the UL code. I've been told I...
If you push the tub to any side it should not be real easy and come back to the center with some force. If the above is good you shouldn't need springs. make sure that you load it evenly
Sep 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer won't drain and spin. It says "LD" and consistently stops with 24 minutes left on the cycle. For a while if I would spin the basket a little it would work. Not that...
There could be several things causing this problem. Have any small items gotten caught in the pump or between the basket and tub? You may be using a cycle with a low spin speed. If you need to remove excess water, select the Drain and Spin option. If the load is tightly packed it might cause the problem you're having. Are you using ONLY "HE" detergent? If so, be sure you're using the correct amount. To clean out residue from too much or wrong type of detergent select the "Rinse and Spin" option but do NOT add any detergent.
I hope this information helps. If it does, please rate my suggestion and its effectivness. Thanks!
Jun 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio WTW6200SW1; spin cycle loud roar
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 07, 2010 | Washing Machines
Whirlpool WTW6500W Washer Logo
46 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
