Lift the scanner cover so that you can see the platen glass. Look to the left of the large sheet of glass and you will see a narrow strip of glass. This is the area used to scan documents fed from the ADF. Make sure that this glass is very clean. Use a damp cloth to clean any dirt or buildup.
For horizontal lines, try using the HP "toolbox" to clean the print heads. You may need to repeat this process until you achieve a satisfactory result.
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer. see if it works.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.
You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Well I hate to give out bad news but if that line is in the exact same location on every scan it means that the element (the scanning light) has failed. Sorry that I could not earn a FixYa for you. If you need to replace the scanner I have had excellent luck with Epson scanners. Here is a link to a few on Amazon.com for refrence. http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps &field-keywords=epson+scanner&x=0&y=0 Just copy the link and paste it into your web browser. there are also some very good all in one options. I have had this one for a year and it works well: http://www.amazon.com/C7280-Photosmart-All-Printer-CC567A /dp/B000UY6M2G/ref=pd_bbs_sr_4?ie=UTF8&s=office-products &qid=1210270089&sr=8-4
