Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
Ness NZ Posted on May 08, 2012
Panasonic TH-42PV500A Base Stand
Hi there, we purchased a second had base stand for this tv.. but the tv seems to be leaning forward... Any ideas as to what the problem may be? thanks
1 Related Answer
Anonymous
  • 298 Answers
  • Posted on Mar 26, 2008
SOURCE: Panasonic TH-42PD50U Base Stand
Unfortunetly, this part has been discontinued by Panasonic. You may want to try ebay to locate this item. The part number you are looking for is TY-ST42PX5W. Good Luck!
How do I remove the TV stand from a Panasonic 50Px80U?
Do you mean the original pedestal base for the Panasonic TH-50PX50U? The base has two vertical posts that fit into recessed areas in the TV. Then four screws (two per post) secure the TV and base together. To remove the base, place the TV screen down on a solid surface that is covered by a clean soft cloth. Remove the black M5x25 screws and slide the base away from the TV. To store the pedestal more easily, remove the 4 silver M5x18 screws that secure the posts to the base. A Philips head screwdriver is needed. Save all of these parts in case you need to put the pedestal base back on the TV.
See page 7 of the Quick Start instructions here: https://pdf.crutchfieldonline.com/ImageBank/v20090127124100/Manuals/133/13350PX80.PDF .
I hope this helps.
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
1helpful
Can remove stand from television
Yes you can remove the stand from the television for wall mounting purpose.Just unscrew the four screws marked by the yellow circles. Lift the TV up while somebody holds the base down or it will lift along with the TVand fall. Make sure you take help from one more person while doing this.bobhifi_22.jpg
1helpful
2answers
I bought a used panasonic TH-50PZ85U plasma TV that was wall mounted. I need a pedestal base. Called Panasonic 3 days ago and the have to "research it". Can you help? km
My ex-husband threw away the pedestal stand for the Polaroid Polaroid FXM-3211C TV DVD Combo which I now have. I need a pedestal stand....do you know where I can find one?
LG - 32LG20 - Excellent LCD TV, but the stand is junk
there are four screw holes at the back, you might want to make use of it for anchoring. I guess these models are designed for TV-like installations and not for computer desktop monitors. The base takes a lot of space too.
2helpful
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
