Why can't you change the bios setup to change the boot order or boot sequence?
Also you can change the boot order or boot sequence temporarily by just rebooting the laptop then watch the screen for which key it says to hit to change the boot sequence or boot order, then hit that key when you see the message.
SOURCE: Boot sequence / bios password issues with Acer Aspire 5100
The finger print bull is how that password came up for me and they want a 125.00 to remove it. I called the better business bureau and filed a complaint. They shouldn't have any right to control your laptop. I to have a 6292 , took it apart as far as I could and could not find jumper or password. This is a gimmick to make money.
SOURCE: IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
SOURCE: ACER ASPIRE 5100 DVD/CD ROM IS NOT DETECTED IN BIOS?
do you get an error 200 yet ? i got one here that does the same thing and its a bad motherboard. tried to replace cd drive and harddrive and was no help
the motherboard cost to much and not worth the part and labor
SOURCE: Acer Aspire 5100 Stuck in eRecovery boot loop.
You are going to need a boot up partition manager likeon the Ultimate Boot CD (ultimatebootcd.com). Boot to it, go into the partition program, then set the active partition back. Thanks and please take a moment to rate as fixya.
SOURCE: cant install xp to dell c400 with external cd-rom
This is how I did it, you may or may not have the ability. A basic knowledge of Dos is necessary 1) I used another laptop but you could use an adapter to use the hard drive in a regular computer. 2)boot with a windows 98 boot disk, fdisk it to a fat32 partition, make the hard drive a system boot disk (format /s c:) 3) copy the i386 folder and all its contents from a full or full oem (not branded) disk to the laptop drive, also copy smartdrv and highmem.sys from the floppy (speeds thing up dramatically) and create a config.sys file with device=highmem.sys 4)physically install the hard drive back into the C400, boot to dos run smartdrv.exe, then go to the i386 folder and type winnt.exe (enter) wooo should work. MusslaChooda Pakichooda Nathuram Godse
