Problem: Canon SLR Rebel XT, fully charged,on a sunny day, set on AUTO setting,however, camera kept taking timed shots ?! Regards MDWhittingham
SOURCE: Canon EOS Rebel K2 35mm SLR Camera troubleshooting forum
Go to the link below for owner's manual. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=214&modelid=9429 Once you are on this page, click the "Drivers and Downloads" tab near the middle/right of the page. Next, click on the red letters that read "Product/Software Manuals." A new pop-up will appear displaying Canon. (NOTE: You may have to temporarily allow the pop-up.) At the bottom of this page, click on EOS_REBEL_K2.pdf and open. Then go to page 24. Good luck.
SOURCE: Rebel EOS Rebel SLR film camera-pictures develop like film was exposed
The shutter is most likely damaged.
SOURCE: canon k2 manual
Hi- here is a link for your manual. If this solved your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=313&modelid=9429
Jeff
SOURCE: low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
SOURCE: My Canon EOS Rebel 35mm SLR camera seems to be
One of the shutter blades is faulty or is being obstructed. Either that or you're using flash to take pictures but using too fast a shutter speed, most SLR's have a flash synch speed of 1/60 or 1/125 of a second.
The first problem will need a professional repair, but it may be a fairly straightforward one. The second problem would require that you read the user manual for both the camera and flashgun.
