Question about Quinny Buzz Three Wheel Stroller
Tightening up frame on quinny buzz - Quinny Buzz Three Wheel Stroller
6ya staff
SOURCE:
Anonymous
  • 50 Answers
SOURCE: have a quinny buzz frame,
go to http://www.user-manual-search.com/search.aspx?search=quinny%20buzz%20frame and choose the 6th tab down...download this manual and it should tell you everything you need to know.. easy as pie....hope this helps...
please rate, i appreciate it...
Posted on Jan 13, 2009
jackiaria
Jack Iaria
  • 350 Answers
SOURCE: Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
Posted on Jan 22, 2009
Anonymous
SOURCE: Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
Posted on May 30, 2009
Anonymous
  • 60 Answers
SOURCE: quinny buzz 2006- if i got a new frame would the
Yes it will
Posted on Aug 17, 2009
SOURCE: does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
Posted on Sep 06, 2009
Frame feels really loose is there any way of tightening it up?
Hi Viccie
It would be recommended that it is returned to the engineers for inspection & repair work required.
Please visit the Quinny Facebook page for assistance in doing this depending on which country you are based in and the age of your Quinny chassis.
Quinny
Feb 23, 2014 | Quinny Buzz Three Wheel Stroller
Can a Maxi-Cosi Mico infant car seat fit on a Quinny Buzz 2006 frame?
The Mico is a USA model only so we are unable to advise from the UK team whether it is compatible with the older style Quinny Buzz.
We recommend you contact Dorel USA on crelations@djgusa.com
Nov 27, 2011 | Quinny Buzz Baby Gear
Hi, the frame on my quinny buzz 3 seems to become very loose i,ve tried tightened the screws but still appear loose is there any quick fix u would know?? thanks
Good Afternoon
If you've tightened the chassis screws there would be no other "quick fix" that can be recommended.
If the product is under 2 years old please contact your retailer with your proof of purchase for them to send it to the engineers under warranty terms and conditions.
If the product is over 2 years old or you do not have proof of purchase please go to www.quinny.com and select the country you're in then go to "Contact Us" to get in touch with the customer service department in your country.
Jul 11, 2011 | Quinny Buzz Three Wheel Stroller
Hi, My Quinny Buzz was damaged by Easyjet and I need to buy a new frame. Where can I buy just a new frame please?
Contact Quinny (go to the we site and call them direct). Its the only place to get just the frame... $211 (that's with tax) Not bad. :)
Feb 11, 2011 | Quinny Buzz Three Wheel Stroller
I have a quinny buzz 2005 frame will a replacement seat unit fit this and will the carry cot fit please
Good Afternoon
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Jan 11, 2011 | Quinny BUZZ 3 Capri Stroller
New seat frame for quinny Buzz
You can purchase a new seat frame only by contacting www.quinny.com.
Hope this helps.
Mar 08, 2010 | Baby Gear
Can a buzz seat fit speedi frame
No unfortunately not. The Quinny Dreami carrycot can be fitted as can a maxi cosi car seat using adaptors but not the buzz seat unit.
Mar 06, 2010 | Quinny Buzz Three Wheel Stroller
My quinny buz 4 frame is very loose and i cant tighten it up anymore, it is very squeeky and the seat looks like it tips back too far
Quinny frames come with a 2 year manufacturers warranty. Contact your retailer or Quinny directly via http://www.dorel.co.uk/contact-us/ if you are still within this period
Aug 10, 2009 | Quinny Buzz Jogger
Does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
May 16, 2009 | Quinny Buzz Jogger
Quinny Buzz Three Wheel Stroller Logo
330 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
