Motor brushes worn or loose. Replace them
More often than not the drain pump runs on for a few minutes after the spin das ended. It may be your pressure switch is a bit blocked, but that usually stops the water filling, or conversely, allows it to overfill. Try the brushes first. I'm 90% it's them
Does that mean it's an induction motor fed by a pcb? Check there isn't an "out of balance" switch fault
Only thing I can come up with is no power from relay on pcb. Is there anything at the motor?
SOURCE: washing machine wont fill with hot water
if you pull the filter out of you (hot water) valve with a pair of long nose pliers you will see a black rubber seal. pull this rubber ring put as it acts like a restrictor.
SOURCE: Fisher and paykel GW611 excellence top loader wont
Check Out Of Balance switch This will prevent spinning and programme from advancing
SOURCE: washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
SOURCE: Fisher & Paykel GW611 Not filling with water
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
SOURCE: I have a GWL11 Fisher&Paykel top loader
The fault code 130 is for Rotary Position Sensor fault. RPS is an electronic component which is neccessary for the motor to turn. It may have failed because of water leaking through the shaft seal. In this case water will have spun out onto the insides of the cabinet. This situation is probably a message to replace the machine.
If the inside of the cabinet is clean and the RPS is the only problem you would be well advised to call a serviceman. The RPS is a little tricky to get in properly and a serviceman will warranty his work.
It is not a big job for an experience tech. Get quotes.
Good luck.....Nomess
Thanks Mike, sorry for late reply as I was away for a week. I have noticed one more thing that, when I try to spin, the drain pump doesn't stop even though tub is empty..
Thanks Mike, but I've got smartdrive in washer and I refer the parts manual, it shows that, rotor would be stationary and stator will move, I've cleaned Pressure sensor and tube as well. still symptoms are same.
Hi Mike, out of balance switch below the controls board is ok.
