Slendertone Fortex Logo
A
Anonymous Posted on May 09, 2012
Slendertone flex e002 - Slendertone Fortex
Canon imageRUNNER 2204. How to reset Canon 2204 error E002-0000?
Question edited for a lot more clarity and spelling of maker name.
Error Codes > Canon > iR1435 > Code E002 0000
Printcopy.info https://printcopy.info > code=E002 0000
Code: E002 0000; Description: Fixing assembly temperature rising error; Causes: The fixing assembly does not rise to the constant temperature within ...
ERROR E002 on my brand new Slendertone max. What a.
The machine is faulty. Contact the seller or Slendertone and return it under warranty.
https://www.google.com/search?q=Slendertone+max+ERROR+E002
I want to watch the get started video on The Flex Belt, How to get started.
Flex Belt - YouTube
? 8:16
https://www.youtube.com/watch?v=gBYvxDeb5VY
Jun 28, 2013 - Uploaded by flexbeltabbelt
We've created helpful videos that will walk you through the easy set-up process. It is very simple to set up The Flex Belt and only takes a couple of minutes... ... tips for awesome results and help you with any questions you may have. ... Getting Started with your Flex Belt - Duration: 8:08. by flexbeltabbelt ...
The Flex Belt video review - YouTube
Slendertone keeps beeping
the beeping its becouse there is no contact between the pads and the skin (1), or the cables and the pads (2), or the cables and the controller (3).
what the manufacturer says:
try to change the pads by new ones
i did that, but still not working.
what i do:
i had the second problem, but i fix it, i cut the cloth in the back part of the pin (not in the front of the pin), and i discover that the cable that is attached to the pin was cut, i remove the the pin, then i replaced with a bolt, i attch the cable to the bolt and thats all.
i'm using it right now and its works great.
i answer on another post similar to this one, a put a link to my google account where you can see pictures of what i did.
thums up! thank you!
My slendertone wont turn on. it did and i turned it off!! and when i went to turn it back on it wouldnt turn back on and i have changed the baterys!!!
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
Bought Slendertone Start but lost instructions so dont how to use.Would like the instructions for slendertone start
Manuals for the various Slendertone products can be found here:
https://www.slendertoneusa.com/t-manuals.aspx
There does not seem to be a manual specifically designated for 'Slendertone Start'; is that a specific product or a program for using one or more of the Sendertone products?
How do you work the Slendertone Belt? I lost the
hold it in front of you comfortably and pull outward (its pretty straight forward)
Top Slendertone Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
