I am using a Mac Book Pro with the projector, running on Snow Leopard. The projector worked fine until I let someone use it about a month ago. Not sure what they could have done to it.
SOURCE: Lamp is on but not no signal from projector coming out !!!
i figured it out. open it up, and make sure the ribbon cables are securely plugged in.
SOURCE: Epson EMP-74 - Blinking Red Light
Hi Sootycat
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This
sounds like the LCD panel used for the blue color has gone out. The
image is made up of red, green and blue images layered upon the screen.
If the blue panel has gone out then there is nothing filtering out the
red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It
could be a simple open and reconnect fix. I personally have never
opened a projector, so I'm not going to walk you through it as I do not
know how hard it would be to tinker with. It should eb a cheap fix for
a true repair man though.
SOURCE: my epson Emp-53 projector lights up then shots off
Possible hardware failure, unfortunately.
Disconnect it from all the devices connected to it. Turn it on and off.
You can also log on to epson.com to check the user's manual http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=19626&prodoid=25951376.
If your unit is still under warranty please contact epson support to get a replacement.
If your unit is not under warranty anymore, please log on to epson.com. Go to the drivers and support page and click on help me find a service center to send your printer to an epson certified servicer near to your area.
SOURCE: lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
