Hello! I have a Dyson DC17 and I am having problems vacuuming over our new carpet. It is a new carpet with a thicker pile than we previously had, but it seems like something more may be wrong. It feels like I am trying to push it through wet sand when I try to use it, even on thinner area rugs. Any suggestions? I've checked the small belt in the front which is intact. And the bar does spin manually.
Hi Julie,
I'm sorry to hear you're having difficulty using your DC17 on this particular carpet type. I'd encourage you to contact the carpeting manufacturer for advice, as they should be able to recommend the best way of cleaning it.
If you'd like any further assistance with your machine, please email us on [email protected], or give our customer Helpline a call on 1-866-693-9766.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
SOURCE: Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
SOURCE: i am try to find Dyson DC17 Vacuum Belts can you
You need this belt here:
DC17 Replacement Belt
SOURCE: My Dyson vacuum brush does not rotate even though the
Hi its Darran at Dyson.
Please contact our Helpline on 1866MYDYSON as it sounds as though we may need to arrange for the machine to be repaired. One of our advisors will be able to run through some checks over the phone with you so please ensure you have your machine with you when calling.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
SOURCE: I have a Dyson all-floor model (not the ball). I
Sure, on the side of the machine you will have a knob, you can use this to tuirn the brushbar off and have suction only.
