If you deactivated your account, you can reactivate it at any time simply by logging in with your login email address and password.
https://www.facebook.com/help/?faq=212666185422169
SOURCE: My email was used to confirm another account,my facebook gone now
Hi. I had a similar problem... it can be fixed! Email facebook and explain what happened. Be patient and persistent.
send email to:
[email protected]
the first email I received back from them (day after I emailed) was generic saying:
"Our records indicate that there is not a disabled account associated with the address you are writing from. If you are referring to another account that has been disabled, please contact us directly from the email address you use to log in to that account..."
Except the email I was using DID belong to my missing account. So I replied with the SAME original message. And detailed what happened to my account.
I received a SECOND response, identical to the first.
I emailed them AGAIN detailing what happened.
FINALLY (about 1 1/2 weeks later) I received this email:
"Hi Chelsey,
Your original account has been reactivated and you should be able to access it now. Sorry for the inconvenience. If you have any further questions, please visit our Help Center at the following address:
http://www.facebook.com/help.php
Thanks for contacting Facebook,
Lo
User Operations
Facebook"
IT CAN BE RESTORED!!!! :) [email protected]
SOURCE: how to reactivate facebook account?
You're just going to have to make a new one...you can still use the same email address since it's deactivated, so if it says that the email address already exists, then you have to reactivate it a different way.
SOURCE: my facebook account iss deactivated
1) Log-in with your email and password 2) There will be a red sign that says you have tried to log-in with a deactivated account. They will use your email that you used to register to send an email about reactivation. Subject should be: “Facebook Reactivation Confirmation” 3) Click on the link when you receive that email and you will be good to go!
SOURCE: Facebook
Change the password of the account from which you login in facebook for example Hotmail.
Now go change your fb password and deactivate your account.
