When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
MY PROBLEM IS THAT MY PRINTER WRITE ERROR 6500 WHEN PUT ON PLEASE I NEED HELP TO FIX IT
FAX machine sends but doesn't complete connection, error report is busy/no signal. I have had the phone co check external line and private tech check internal line. Unable to receive also. Unit worked fine for two months after purchase then problem suddenly showed up. Called Canon tech support but no help after resetting Fax options. Tried several FAXes to various numbers. HELP!
Try disconnecting the printer cord from computer. I have this same problem at work. For some reason when you pull out the printer cord, the fax will send and receive. I don't understand and it's very FRUSTRATING!!!! I just plug in the printer cord when I need to print a document from the computer. Then, pull the cord back out so you can receive faxes when you are away!
Make sure you use an anolog phone outlet.
Then in setup and the area code and phone number.
Place paper in tray, push fax , then dail number to fax to. The machine has to set to receive a fax .
FAX machine sends but doesn't complete connection.(Rings but no pick up). Phone co and tech checked internal and exterior lines. Product worked fine for two months after purchasethen problem. Called Canon tech support but no help after resetting FAX options. Error Report: Busy/ No Signal.
i have an mp830 canon which i cant send or receive faxes from..i believe i have it hooked up ok but when i try to send a test fax from work to home it doesn't work...in a step by step process how do i fix this problem ...any help appreciated...thankyou
Interface with computer and MP830 work fine. Dial appears normal but no response. Phone line checks OK with my HP MFC. Re-installed all drivers and no change. MP830 does not appear to sense dial tone????
I have exactly the same problem as above. Cannot receive nor send faxes. It has worked now for two years up till today. Help
