Volume level is stuck at 15, won't go up or down?
SOURCE: Creative Zen V Plus volume control unresponsive
someone probably put a password in the volume control thingy
to change just go to settins and then where it says volume
if you cant go in it might be somone changed the password
SOURCE: Volume button seems to be stuck
The volume bar of my mp3 seems to go down, I dont know what to do??????!!!!!!>>>>
SOURCE: cannot adjust volume
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
SOURCE: The volume control is frozen on the lowest level.
The manual gives next steps to setup the volume:
1. Press Menu button to return to the Main Menu.
2. Move down to Settings and select it.
3. Select Volume.
4. Highlight the desired volume settings then press Select button.
Manual in pdf format for the Sansa Clip:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
